I am working on a plasma ignition for engines. I use a capacitor discharge and need help finding the right capacitor for the job. I am not sure what value I need. The system uses 110 vac and the capacitor will be discharging every time a cylinder fires. On an 8 cylinder engine at idle that would be 13 times per second. at wide open throttle it could be as much as 100 times per second. I have used a 90uF 250vac cap in the past with good results. Should i use a 120 vac instead and does the 90 uF cap fit my 13 to 100 cycles per second load?
