fibre optic problem
Discussion in 'General Electronics Chat' started by mik3, Apr 17, 2008.
  1. mik3
    Thread Starter Senior Member
    Feb 4, 2008
    4,846
    63
    hi guys, i have a problem for you.
    An optical fibre has core refractive index n1=1.5 and cladding refractive index of n2=1.45. Estimate the maximum signaling rate attainable if the optical fibre has a length of 10Km.
    Can you solve it for me? In my opinion you cant solve it because you dont know the diameter of the core of the fibre, what do you think?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Ten clicks suggest single-mode fiber. Assume either 8.5 or 9 micron.
  3. mik3
    Feb 4, 2008
    4,846
    63
    Thanks for the reply but i want to ask if you can calculate the signaling rate of an optical fibre without knowing its core diameter, do you?
  4. kkm557
    Apr 19, 2008
    If you assume it is a single-mode fiber, there are equations that you can use to estimate "d" as thingmaker3 has. The way I would do it would be to find an approximate V number.
  5. mik3
    Feb 4, 2008
    4,846
    63
    Ok but can you calculate the signaling rate without knowing the diameter of the core?
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Someone else might be able to, but I sure can't.
  7. mik3
    Feb 4, 2008
    4,846
    63
    i think its impossible to do it. You have to know the diameter of the core.
