Fibonacci circuit help
Discussion in 'Homework Help' started by Uyet123, Mar 27, 2015.
  1. Uyet123
    Jan 25, 2015
    29
    HI, I am doing an ASM for a fibonacci sequence, but I am getting this error from logisim. Can someone help me fix this, I have been trying to for hours already but no success. New_Picture_2_.jpg
  2. WBahn
    Mar 31, 2012
    18,096
    4,920
    Could you describe your design and how you are attempting to solve the problem?
  3. Uyet123
    Jan 25, 2015
    29
    Nevermind, I got it working. I have to display the digits on a 7 segment display, I am thinking of using binary to bcd, but how do I start on it? Do I make a state table first?
  4. WBahn
    Mar 31, 2012
    18,096
    4,920
    Binary to BCD can be done combinatorially.
  5. crutschow
    Mar 14, 2008
    13,527
    3,393
    But that can require a lot of logic.
    Here's a discussion on other approaches for binary to BCD.
  6. LimOn Khan
    Apr 6, 2016
    Can You please describe where the start, reset, stop point going? Which circuit is it?
  7. Michael Grenader
    Dec 27, 2015
    hey, can you explain me how you did the circuit? or send me what you did? that will help alot
  8. MrAl
    Distinguished Member
    Jun 17, 2014
    2,580
    524
    How many digits do you have to show?
    If it is a small amount then logic works ok, but if you need like 6 digits probably do it in code. There's an algorithm on the web called something like "double dabble" which i have used several times and it doesnt take up a huge amount of memory space.
    Example:
    0000 0000 1111 start with 0,0,15
    0000 0111 1000 shift left 3 times
    0000 0011 1000 add 3 to center group
    0000 1010 1000 result
    0001 0101 0000 shift left 1 time, result is 1,5,0 which is read "15" in bcd.
    There is a little more to it so you'll have to read up on it.
