Fiber Optics Synchronization tunable delay
Discussion in 'Homework Help' started by cl10Greg, Nov 14, 2014.
  1. cl10Greg
    Thread Starter Active Member
    Jan 28, 2010
    49
    Hello Everyone,
    I am working on a homework problem that I have attached below that is based out of Optical Networks: A practical approach 3rd edition. So the outcome needs to be an algorithm to represent the tunable delay.
    So the way I am picturing it is that there is two signals that both have period T that are out of synchronization by z. So I need to find a formula to represent z to align the two signals. The 2x2 switch can either be cross state (c = 0, adds delay) or a bar state (c=1, no delay). Each delay is in steps of T/2^k-1.
    So from a logic point of view I am picturing a feedback system to tune in the delay.
    • Find the starting value of z (signal 1 - signal 2)
    • signal goes through crossed 2x2 switch (c1 = 0)
    • Find new z after delay (signal 1 - signal 2)
    • If z > 0 +- tolerance
    • ci = 0
    • calculate new z
    • Repeat until z is within a tolerance of 0 so the signals are now aligned
    • Count the amount of repetitions to determine the number of stages to make this happen.
    This is course tuning (I don't need fine) but I need a way or some guidance on if my thinking is correct and how to correlate that to a algorithm. Also, what is the point of the bar state if I am most likely never going to use a pass through of the switch? I guess if the delay went past the synchronization point but then I would have to tune the other signal but really we're only manipulating the one signal to match the reference signal. Any thoughts or help is appreciated.
    • HW2.pdf
      File size:
      121.8 KB
      18
  2. atferrari
    Jan 6, 2004
    2,663
    784
    Your .pdf is password protected.
  3. cl10Greg
    Jan 28, 2010
    49
    Hah woops. Use this instead.
