fiber optic test procedure
Discussion in 'Embedded Systems and Microcontrollers' started by AHMARAFAH, Apr 29, 2009.
  1. AHMARAFAH
    Jul 11, 2006
    20
    hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
    can any one please,guide me to the best way in order to test fiber optics cables in the site to be assuring that at operation it will work properly.Also,the proper way in order to earth wteel wire armoured cable for single and multicore
    thanks in advance
  2. gryskop
    Member
    Mar 1, 2008
    26
    Fiber optic splicing is a specialized process.
    When a cable is pulled, a quick test can be done by using a laser diode (a special tool that we bought from a fiber cable supplier) and do a visual optical test. Once the splicing is done, the company that does the splicing should supply you with a test certificate that shows the db loss over the length of the cable. Unfortunately there's no "quick and dirty" solution for this.
