I want to buy a device without to program a CPU that does the transform FFT for 20 500 Hz frequency. I know that is devices that do FFT for the frequencies of the AUDIO Where I can buy devices that do FFT for 20 500 Hz
FFT is an algorithm that give a numerical result as the output. It is not some physical device say like an OPAMP. So I think we need much more information about your project, else we will not be able to help.
The Fast Fourier Transform is a digital algorithm. As such it requires a digital device to implement it. To create something remotely similar in the analog domain would require a collection of sharp bandpass filters, say ten of them. Feed the same signal to each one and the output of each filter will be the amount of energy in each passband.
This will be way more trouble and expense than using a DSP chip. Much less flexible as well. I gaurantee you will be disappointed with the results of such a "crude" analog spectrum analyzer.
