ffc/fpc connectors 16pin HELP
Discussion in 'Electronics Resources' started by paddyhughes086, Nov 20, 2013.
  1. paddyhughes086
    Thread Starter Active Member
    Jan 30, 2011
    48
    Hi i have a spy cam that was mounted into my crashed helicopter.
    I am removing it and placing it into my second helicopter but I need the camera at the front of my helicopter and the circuit board that controls it at the back of the helicopter. As there is no room to have both at the front.
    So I need to extend the flat cable with some sort of connecter and cable extension but I need help in identifying it and getting my hands on a connector THANKS
    Image 1: Camera cable
    is a flat cable like the one laptops keyboards use it is 16pins and is 12mm wide spacing is just under 1mm around 0.7 or 0.8mm
    Image2 : Connector needed
    The connector I want is one it can slide into and you just push down to lock
    Thanks for any help
