I will definitely look at your blogYou just noticed a bad design choice. Look at my blogs about voltage regulators. They show how to get to a zero output voltage and how to float the regulator. You can get to zero with an LM723, but it requires a dual voltage supply to get there. The OP-07 is an accurate chip, I just can't remember if it will work with a single supply.
