fetch & execute
Discussion in 'Homework Help' started by zulfi100, Mar 22, 2013.
  1. zulfi100
    Jun 7, 2012
    320
    Kindly guide me with the following question:
    My solution is based upon 8-bit data bus is:
    1. get instruction (3 units time)
    2. get operand A (1 unit of time)
    3. get operand X (1 unit of time)
    4. Store data (1 unit of time )
    total time=6 units
    Plz guide me with the correct answer.
    Zulfi.
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Presumably the values are already stored in A and X from as a resiult of executing previous instructions. Thay are just sitting there ready to use.
    Is this a von Neumann machine or a Harvard architecture?
  3. zulfi100
    Jun 7, 2012
    320
    Thanks for your interest in this question. I have written the entire question. It does not give any more information about the architecture. Kindly tell me about the correct answer.
    Zulfi.
  4. WBahn
    Mar 31, 2012
    18,079
    4,917
    With no further information, you have to assume it is a von Neumann architecture.
    So use the hint I gave in my last post.
  5. zulfi100
    Jun 7, 2012
    320
    Thanks for guiding me. If its von Neumann architecture then we cant access the data and instruction at the same time.
    I cant understand:
    Plz guide me.
    Zulfi.
  6. absf
    Dec 29, 2010
    1,493
    374
    Using 6502 MPU as an example:
    Code ( (Unknown Language)):
    1.
    2. LDA #$20        ;ACC = 20H
    3. LDX #$56        ;X REG = 56H
    4. STA $3000,X    ;20H -> MEMORY(3000H + 56H)
    5.
    The 1st and 2nd instruction would set up the Acc and X Reg for the 3rd instruction STA $3000,X
    HTH
    Allen
  7. WBahn
    Mar 31, 2012
    18,079
    4,917
    It's like the following statement in a high level language:
    y = a + b;
    This statement doesn't put values in either a or b, it merely uses the values that are already in them as a result of prior statements.
    In most architectures, you don't have to spend time "getting" operands that are stored in registers. In some sense that's why the registers are there - to make their contens immediately available to the instruction being executed.
  8. zulfi100
    Jun 7, 2012
    320
    Thanks. I did not pay attention to the fact that A and X are registers.
    So now:
    get inst (3 units)
    store (1 unit)
    So total time is 4.
    Is it right now?
    Zulfi.
  9. WBahn
    Mar 31, 2012
    18,079
    4,917
    That would be my best guess.
  10. zulfi100
    Jun 7, 2012
    320
    thanks for providing me insight in this question.
    Zulfi.
  11. WBahn
    Mar 31, 2012
    18,079
    4,917
    No problemo! Glad to see you getting a handle on some of these things.
