Fet selection
Discussion in 'General Electronics Chat' started by tigerk2001, Jan 7, 2010.
  1. tigerk2001
    Jan 7, 2010
    8
    By using a 555 astable cicuit connected to a FET and bipolar transistor , I want to duty cycle control a high voltage source.
    The astable is configured for 50% duty cycle and is used to switch a 12VDC source to the primary side of high voltage transformer.
    What is the best transistor and/or Fet configuration to use.
    Can someone give me a proposal for the schematic to follow and piece part number to use? The Fet need to drive 2 Amp.
    Many thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You should look at Ronald Dekker's Flyback Converters for Dummies page:
    http://www.dos4ever.com/flyback/flyback.html
    I'm assuming that you are using the supply for electron tube/valve plates.
    Keep in mind that dealing with high voltage, particularly when stored in large capacitors, can have lethal consequences. If you are new to electronics, stick with projects under 50v for a year or so.
  3. VoodooMojo
    Nov 28, 2009
    503
    53
