FET or IGBT?
Discussion in 'The Projects Forum' started by auvie, Dec 27, 2013.
  1. auvie
    Oct 8, 2013
    25
    Hi all,
    My circuit has a capacitor discharging through a bunch of LEDs, with a peak current of ~150A over 5 ms (max 0.5% duty cycle). I'd like to use a FET or IGBT to switch the circuit and control pulse time, which will vary between 1ms and 5ms.
    I would like to minimize Rds voltage/resistance, with an on/off switching time in the range of tens of microseconds. Can anyone recommend a FET or IGBT that might be suitable for this application?
  2. ronv
    Nov 12, 2008
    3,392
    1,447
  3. easyeda
    Oct 22, 2013
    I vote IGBT.
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    IGBT's have a much higher ON voltage then a MOSFET so, unless the voltage exceeds those available, I recommend a MOSFET.
  5. auvie
    Oct 8, 2013
    25
    Thanks all for your input, forgot to state the cap voltage, it's 50V. That IR part might to the trick, will take a closer look, thanks ronv.
  6. auvie
    Oct 8, 2013
    25
    wow excellent, that part has a very low Vds and Rds, almost negligible. Do you have any circuit/IC recommendations to help an AT90PWM3B drive it?
