FET Help
Discussion in 'General Electronics Chat' started by arthur92710, Dec 1, 2007.
  1. arthur92710
    Thread Starter Active Member
    Jun 25, 2007
    307
    I have a IRF540 FET and i need it to be switched on and off with a 555. It will power something that needs more current then the 555 can out put so the Fet drain and source will be connected directly to the battery. But when i do this it does not work right. It looks like the 555 is powering the led and not the 555.
    I tried various configurations of the pins but they all work the same way.:confused: Can you help?
    video
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you provide a diagram of the circuit?
    hgmjr
  3. arthur92710
    Jun 25, 2007
    307
    Sure it the same one I posted in a different post. Here
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I watched the video you provided and I observe what you are talking about.
    I wonder if your FET has been damaged perhaps. ESD perhaps has done it in.
    hgmjr
  5. arthur92710
    Jun 25, 2007
    307
    OK ill try another fet
    ok a new fet helped
