FET as a switch and FPGA ?
Discussion in 'Homework Help' started by sstbrg, Jun 21, 2009.
  1. sstbrg
    Thread Starter Active Member
    Nov 29, 2008
    54
    Hello!
    Well, my task is to switch 28 volts to activate a 28v/50mA dc lamp using FPGA.
    Relay is not an option. One of the lamp's pins must be connected directly to the ground.
    My idea is to take an optocoupler (without base connection for now) and connect it to the 3.3v output of the FPGA (with some resistor in series). Then the collector pin will be connected to 28v (or 5v), the emitter pin will be connected to the ground through a 100k resistor. The output will be on the 100k resistor, connected to the gate of a N-channel JFET or MOSFET. The drain of the FET will be connected to 28v, and the lamp will be connected between the source and the ground.
    This is to ensure that there is no possible relationship between the FPGA and the FET.
    Also, is it possible to use a p-channel [mos/j]fet for this task?
    If so, how? If not, then why not?
    Thanks for all the fish :)
  2. Bernard
    Aug 7, 2008
    4,248
    424
    Just something to think about.
