ferrite vs iron powder
Discussion in 'General Electronics Chat' started by lokeycmos, Aug 11, 2011.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    is there a way to visually tell the difference between ferrite and powdered iron cores? i have a box full of round and rods and just wondering.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If they have a part number on them, you can sometimes find who made them, and then their specifications.
    There is "sort of" a standard color coding used on powdered iron cores, but the ability to order toroids with any color you want on them (or uncolored) pretty much negates going by color.
    If you just have a pile of them, you can start by wrapping on 20 turns and seeing what their inductance is. That and the dimensions will give you a starting place towards finding out what they really are. But, you really need to take measurements over a fairly broad frequency spectrum to find out where their Q peaks.
    For example, a T50 #6 material toroid will have its' peak Q (~220) with 25 turns wrapped on it @ ~9.5MHz. By 12MHz with 19 turns, the Q drops off to ~205. Down at 4MHz with 62 turns, Q drops down to around 200. Different materials have different Q curves.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    A magnet will stick to the iron powder cores but not the ferrite ones.
