Ferrite beads in logic circuits
Discussion in 'General Electronics Chat' started by harrison2015, Apr 29, 2015.
  1. harrison2015
    Apr 22, 2015
    80
    I see these ferrite beads tied to +VCC like pull up resistors in logic circuits. What do these ferrite beads do that are also tied to +Vcc. The ferrite beads look like pull up resistors on the inputs and output of logic chips and also on the power pins of logic IC chips. The Ferrite beads smooth out the fluctuations, noise and ripple in the DC, anything else they do?
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Ferrite beads are usually aimed at the higher (HF/RF) unwanted frequency pulses.
    Max.
  3. harrison2015
    Apr 22, 2015
    80
    the ferrite beads are in the VCC rails for TTL and CMOS logic
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    those are uses to filter out rfi/emi. prevent rf radiation. they started using them a little after pac man came out to filter rf radiation from the games. worked for that, didnt work for the game due to ringing of the ferite choke and shunt caps falsing inputs when exposed to static discharge.
  5. harrison2015
    Apr 22, 2015
    80
    how does ferrite beads filter out RFI/EMI frequencies? why can't a capacitor or inductor do this
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    because it adds inductance to a wire run through it. not a lot, but enough at higher frequencies where the intrferance is worst. using both caps and beads, usual.ly in a Pi configuration, works best. shunt cap, series inductor (ferite) and shunt cap.
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    A ferrite bead IS an inductor.
    Max.
  8. atferrari
    Jan 6, 2004
    2,663
    783
    Hola Harri
    He explains the basics. This could help you.
    BTW, explore his list of videos. He is good.
  9. harrison2015
    Apr 22, 2015
    80
    I measured the ferrite beads on a huntron and the signature doesn't look like an inductor signature.
  10. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Would you deny these are (ferrite) inductors?
    Max.
    absf likes this.
  11. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The ferrite bead is roughly the same as a single turn choke on a toroid core - just a lot smaller.
