ferrite bead as low pass filter search
Discussion in 'General Electronics Chat' started by levnu, Apr 7, 2011.
  1. levnu
    Mar 30, 2011
    14
    Hi
    i'm looking for a ferrite bead that will block 1-20 Mhz
    frequancies and pass all lower ones
    is it possible ?
    can someone to advice me for one specific?
    Best regards,
    Arye
  2. levnu
    Mar 30, 2011
    14
    block around 10 Mhz is good enough
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You're probably going to need more than just a ferrite bead.
    Check out Amidon's specifications page on their website:
    https://www.amidoncorp.com/pages/specifications
    Under Ferrite Material, look at:
    2-14 Ferrite Beads https://www.amidoncorp.com/specs/2-14.pdf
    2-15 Beads: Material vs Freq. vs Impedance https://www.amidoncorp.com/specs/2-15.pdf
    2-16 Ferrites for RFI https://www.amidoncorp.com/specs/2-16.pdf
    2-17 Ferrite Cores for RFI Suppresion https://www.amidoncorp.com/specs/2-17.pdf
    If you want to take a shot at designing your own filter, have a look at Elsie:
    http://www.tonnesoftware.com/elsie.html
    The student edition is freeware, limited to 7 poles or stages.
  4. levnu
    Mar 30, 2011
    14
    thanks a lot
    Arye i'm looking at all your links
  5. PackratKing
    Jul 13, 2008
    850
    216
    Welcome to AAC !!
    :) Hope you find what you need. We have a bunch of gals and guys here that are the best there is.
