Swimming pools use by several gallons (2 liters?) per treatment, and pools get several treatments per year. A gallon for etching is a 10 year supply, unless you start doing major quantities.
Storage is the major problem, but this is true of all the chemicals. My current technique is to wrap paper towel tight around the lid (rolled up tight) to absorb fumes. Then I put it in a plastic bag because I was still seeing corrosion around the bottle. Both the Ferric Chloride and the Muriatic acid has this problem. I store a small bottle of acid that I use for my immediate use, and keep the large bottle to dispense to the smaller bottle.
The MSDS (Material Safety Data Sheet) sheet I got with the Muriatic Acid says it is 32% dilute (or 1/3 Acid, 2/3 water).
