Ferric Chloride
Discussion in 'General Electronics Chat' started by R!f@@, Jun 9, 2011.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    Been trying to get those but I have yet to find some here
    My friend had some but since he too moved his workshop, they are buried.
    He said to check a UK shop called Maplin. Any one heard of it?
    I think I can pass crystal type ferric chloride. Friend said it is possible, liquid type may be blocked.
    So, does any one know where I can buy some solid ferric's that can be dissolved to form the necessary liquid types.
    Any thing I should be aware of using these types or liquidating these.
    I just wish the customs don't confuse them with crystal meth. :eek: when I import them
    I checked ebay and found some two types of 'em. This and these
    Which is better ?
    Does the type of ferric differ in using different types of clad boards?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    PackratKing and R!f@@ like this.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Maplin are reliable, if a little expensive, but if their shipping charges are ok then go for it. I couldn't find any etchant on their website but I didn't look too hard. I've bought it from them before.
    www.maplin.co.uk
    Sodium persulfate is another option for etching, also available as powder.
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    Assuming you are trying to use this as a DIY pcb etchant you can make a "more environmentally friendly" etchant using Muriatic (hydrochloric) Acid and Hydrogen peroxide. Those "might" be easier for you to get
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Muriatic acid is a dilute solution of hydrochloric acid, is commonly used in the States to lower the Ph of swimming pools, and is readily available at swimming pool supply stores.
    You should be able to find hydrogen peroxide at any drugstore or in the health section at a grocery store (if they even have large grocery stores in the Maldives; I don't know).
    You pour two parts of 3% hydrogen peroxide (by volume) into a container, and add 1 part muriatic acid SLOWLY, stirring as you go. Muriatic acid will eat right through clothing and your skin; keep plenty of fresh water handy to dilute it in case of spillage or splashing. Baking soda neutralizes acid, and it is very inexpensive. Wear rubber gloves, eye protection, and do not use this solution indoors. It will etch concrete, and ruin the finish on many metals (including stainless steel). It will dissolve nylon.
    You can store used etchant for later use (not too long), but don't seal the container air-tight; I put some in a plastic bottle, and the bottle swelled up to about twice it's size due to the continuing chemical reaction of eating the copper oxide. Hydrogen peroxide decomposes into water in light, so it should be stored in a dark place.
    PackratKing, R!f@@ and Jotto like this.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't even try to store the mix, I keep the two components separate and mix when needed. I give instructions for this and more here.
    How I make PCBs
    So Rifaa, ever get the toner transfer to work for you, or are you going with the photographic technique?
  7. magnet18
    Dec 22, 2010
    1,232
    125
    Just to point out, the decomposition results in the release of oxygen gas.
  8. nerdegutta
    Dec 15, 2009
    2,571
    806
    I'm using this:
    It's pretty safe. I've got some splashes on my hands and clothes. No harm done.
    PackratKing likes this.
  9. radiohead
    May 28, 2009
    474
    31
  10. R!f@@
    Apr 2, 2009
    8,793
    771
    OK guys let me check the drug stores for the stuff first.
    @ Bill.
    The transfer method is yet to decide as I have learned recently the transfer method is unique to the clad board types.
    Which makes me wonder what type I have.
    Will post details on this after a trip around Male'.
  11. R!f@@
    Apr 2, 2009
    8,793
    771
    I tried all the pharmacies, all I can get is the peroxide.
    No Hydrochloric possible.
    Any other Ideas guys?
    Is it possible to make the acid with house hold chemicals ?
  12. magnet18
    Dec 22, 2010
    1,232
    125
    Do they have pool stores in the maldives?
    and I don't think HCl can be made easily, but it can be done by bubbling chlorine gas through water or decomposing sulfuric acid, if you had sulfuric acid you wouldn't need HCl, and I don't think you have chlorine gas laying around.
    You might see if acetic acid will work. It might take forever, but it's just vinegar.
    Out of curiosity, do they have chemistry classes in the Maldives?
    [EDIT]
    or some drain cleaners have HCl in them, or if you can get ahold of some NaHSO4 you can make it.
  13. R!f@@
    Apr 2, 2009
    8,793
    771
    We have chemistry classes but access to the lab is restricted.
    I believe hospital lab has hydrochloric, so I am trying to find some one who works in the lab to get me some.
    The peroside I can get is quite cheap. MRF 10.00 for a 100ml I think.
    How much acid would I need to etch a standard 12" by 4" SS clad board. I like to know the amount I would need for 100ml Peroxide.
    Sgt said 2 part of 3% peroxide to I part of HCL.So for every 100ml of peroxide I need 50ml HCL, I believe. But the 3% of peroxide part is confusing me.
    Can any one tell me what the 3% means.
  14. Kermit2
    Feb 5, 2010
    3,854
    968
    It means 97% H2O and 3% H2O2.
    Weak stuff.
    One more thing. If you get the crystal ferric chloride, expect to create an etching solution very slowly. Best if you access to some ice. The process of hydrating the crystals is VERY exothermic. (It gets hot!)
    R!f@@ likes this.
  15. R!f@@
    Apr 2, 2009
    8,793
    771
    shooooot!!..Now I get it. DUH!!!...
  16. MrChips
    Oct 2, 2009
    12,651
    3,460
    See if you can lay your hands on some ammonium persulphate - a lot cleaner to use and you can keep on reusing it by adding an oxidising agent.
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am under the impression that Muriatic acid is universal for swimming pools, so the question about swimming pools in the Maldives is a good one. Aren't there swimming pools there? If there are someone has to provide them their basics.
  18. R!f@@
    Apr 2, 2009
    8,793
    771
    Ammonium persulphate...
    What the heck is that ?
    How can I recognize it?
  19. R!f@@
    Apr 2, 2009
    8,793
    771
    We do have swimming pools bill.
    As I have seen on some guest house buildings.
    You think they will have Muriatic acid.
  20. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Muriatic is a diluted hydrochloric acid. You would not want to use straight hydrochloric acid, as it would eat right through everything - and it would be dangerous to use. Swimming pool "muriatic acid" is at the right dilution for homemade PCB's.
