Ferric Chloride Powder
Discussion in 'General Electronics Chat' started by ISB123, Sep 24, 2015.
  1. ISB123
    May 21, 2014
    1,240
    531
    Hello, I have 250g of FC in powder but I can't figure out how its supposed to be mixed. Some forums say 1/1 ratio,some say 1/2 and some say 1/3.
    On package it says add content in 0.5L of warm water but I doubt that this is correct ratio for PCB etching unless they mean one granule in 0.5L of water.
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    250 grams is .25 liters..
    So 250 grams of powder with .5L of water is a 1/2 ratio..
    Follow the directions..
    ISB123 likes this.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Be very careful, using eye protection and have lots of water available if anything goes wrong.
    Work within some larger container in case of a spill.
    Dont use HOT water, as this stuff can be very reactive. Very mildly warm water may be ok.
    ISB123 likes this.
  4. ian field
    Oct 27, 2012
    4,447
    791
    Usually with corrosive chemicals in crystal/powder form - the chemical should be added to the water.
    Sometimes, pouring water on a heap of reactive chemical causes a........well,er reaction.
    ISB123 likes this.
  5. ISB123
    May 21, 2014
    1,240
    531
    Last time I was dealing with chemicals I ended up dropping an aluminium heatsink in bucket full of HCL, that's when I found out that fumes are pretty good at clering stuffy nose :D.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    Sounds like you shouldn't be using chemicals at all.... no really
  7. ISB123
    May 21, 2014
    1,240
    531
    Robin Mitchell and kubeek like this.
  8. dl324
    Mar 30, 2015
    3,378
    651
    Good advice for mixing.
    When etching, you want the solution to be warmer than the hottest water you can get from a faucet to increase etch rate. I heat my solution in a water bath that's 150-200F.
  9. ian field
    Oct 27, 2012
    4,447
    791
    One of the local biker club told me he put an aluminium cylinder head in a bowl of caustic soda to de-coke it.
    He left it to soak overnight, by morning it was gone - he thought someone must've nicked it.
    ISB123 likes this.
  10. ISB123
    May 21, 2014
    1,240
    531
    He is genius,just like me:rolleyes:. Luckily in my case only the fins got etched away :)
  11. ian field
    Oct 27, 2012
    4,447
    791
    Once I put a Suzuki 50 cylinder, piston and head on a Yamaha 50.
    The Suzuki had a shorter stroke and at BDC it didn't clear the transfer ports, so I put a stack of M6 washers on each cylinder stud to raise the barrel. Originally I cut a cork sheet gasket to seal it, but that didn't last long. In the end I tied a length of bicycle inner tube round the gap - it worked, but every time the engine backfired, it farted!
    ISB123 likes this.
  12. ian field
    Oct 27, 2012
    4,447
    791
    Confusing drain cleaner for bath salts could be rather messy!
  13. 3dOptics
    Member
    Mar 15, 2009
    13
