feeding data to LPC chip using serial connection
Discussion in 'The Projects Forum' started by galanis, Aug 11, 2009.
  1. galanis
    Aug 11, 2009
    Good day
    I am Angelo, and new to this forum.
    I am a big fan of speech synthesis, big enough to decide
    to launch myself into the world of circuits. There was
    this question about the possibility of a project I had in mind
    eventually when I know enough about all this.
    Is it possible to create a (simple) circuit board containing a form
    of connection to the serial port of a pc, a TI TMS5200 LPC chip
    and audio output means (amp/speakers), and pipe LPC data
    to the TMS5220 chip through terminal software ?
    As I understood, the TMS5200 used a PROM called TMS6100
    which contained lpc data to be piped to the TMS5220 chip.
    Documentation on the TMS5200 is way too hard for me still, but it
    mentions that it can read data from something else than the TMS6100
    which sounds hopeful.
    For those not familiar and curious about those two gems, please
    check out http://en.wikipedia.org/wiki/Texas_Instruments_LPC_Speech_Chips
    The manuals can be found at:
    http://www.gamearchive.com/General/Data_Sheets/TI_TMS5220.pdf
    Thank you for your time if you gotten that far.
  2. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    You could try using LPC2138 which is a 32bit chip and can have USB support to transmit audio faster compared to the serial port. What you are trying to achieve is not clear. LPC2138 comes also as a PLCC package.
  3. galanis
    Aug 11, 2009
    Hello and thank you for your reply.
    I aim to one day be able to pass LPC data to the TMS5220 chip
    so I can synthesize speech to a speaker. I thought the simplest way
    would be to connect a board to a serial port of a pc, and pass
    data through a term program. I am actually not even sure it is
    doable. My choice of using the (antique) TMS5220 is purely nostalgic.
