feasability of power invertee working as regen-brake battery charger
Discussion in 'The Projects Forum' started by robo5050, Dec 11, 2007.
  1. robo5050
    Dec 6, 2007
    15
    Hopefully I am posting in the right forum;
    Anyway,I have an electric scooter that is needing-badly-a
    regnerative braking circuit to be switched by the brake switch then
    relay to actuate the circuit
    The problem is could I use a ready made power inverter that puts out 150 watts CONTINUOUS;and if so,how would be the best way to step the voltage down to that of the batteries(the power inverter will put a modified sine wave
    of 110 volts,when 12-15 volts is input;battery pack is 24 volts)????:confused:
    Any helpful tips suggestions greatly appreciated!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Do you have any information on the motor and what kind of voltage/current it puts out when generating? It might be possible to simply feed the motor's output to the batteries for regenerative braking.
  3. robo5050
    Dec 6, 2007
    15
    As far as the motor voltage output goes,I don't know-I do know it takes 24 volts,and has 20 amp maximum current consumption,but haven't been able to test the motors output
    since it would require possibly a motor powered treadmill or something similar.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The battery should be enough load to keep the motor output from going too high, and the motor can hardly generate more current than it consumes at a give speed. You might want to do some research, of course, but the inverter/charger step seems unnecessary.
