Faxitron X-ray machine
Discussion in 'Off-Topic' started by someonesdad, Sep 28, 2011.
  1. someonesdad
    Thread Starter Senior Member
    Jul 7, 2009
    1,585
    141
    I have a friend who has a working Faxitron X-ray unit (see attached picture):
    Faxitron CS-100AC X-Ray Machine (92 KV @ 100 mA) with a Focal Spot: 8 micron, Xray Tube: Stationary anode, end window construction, w/ Beryllium window (0.127mm thick) & 46° (beam angle) • Maximum board size: 18"x24" • Real Time Image Resolution: >26-50 line pairs/mm (magnification dependent) • Camera Type: High Resolution CCD Camera with 6:1 Motorized Zoom Lens • Equipped with: Electronic "Z Axis" X-ray tube adjustment (affects FOV = Field of View, Magnification, Resolution, Electronic "Z Axis" detector motion (expands FOV range & sensitivity) • Equipped with Rotation & Tilt Fixture • Laser Pointer • Cabinet w/casters, leveling pads, lockable storage area, & pull-out printer shelf = 1250 Pounds. Last safety inspection: May 2010.
    I believe he got it as a surplus unit. He's interested in selling it, but has no idea what it's worth (and you don't need to suggest he search ebay, as he's an expert ebay seller and has been looking for a week). It appears that it was once used as an inspection device for PC boards.
    I have two questions for the folks here:
    1. Do any of you have any experience with this device? If so, what is it typically used for?
    2. Do you have any suggestions as to what the unit would be worth?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Alcatel used to have one of those I believe, it's biggest use was looking under ball grid arrays for solder voids, but that wasn't the only use.
    I would focus on the new price, then go from there. Has he contacted the parent company, assuming they exist, for how much they cost new?
  3. someonesdad
    Jul 7, 2009
    1,585
    141
    He finally found out that the original selling price for the device he has was in the $150k-$200k range. But that has little to do with what the thing would be worth to someone today, both because of a depressed economy and I can tell that some of the machine's parts were overpriced.
    Still, if the machine works and is reliable, there's probably an interested buyer somewhere. Perhaps a reasonable strategy would be to put it on ebay with a reasonably high reserve price.
  4. magnet18
    Dec 22, 2010
    1,232
    125
    KEWLIO!!
    I would ask on the 4HV.org forum, theres a few guys on there that used to/still do repair/work on x-ray equipment and they might know more about what it's worth
  5. loosewire
    Apr 25, 2008
    1,584
    435
    Try an animal hospital,may be the best place.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    This machine is not for looking at biological. I suspect to see through metal it has a lot more Xrays, while hospital (animal and otherwise) try to get by with less.
    Note the enclosure, it is designed for piece parts.
  7. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    The machine is probably to look at continuity of traces on the PCB (as the photo show a PCB).
    The X-rays will be much to "hard" for a biological use.
    Biological X-rays are much softer (less energy).
    (they ususaly measure the energy in eV (electron Volts) ).
    Bertus
  8. magnet18
    Dec 22, 2010
    1,232
    125
    I think you may be confused, Bertus.
    The medical x-ray machines generally use harder x-rays that will pass through the soft tissue without being absorbed at all, if they used soft x-rays many more of them would be stopped by the soft tissue and increase the received radiation dose.
  9. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    It could be. The time I had a X-ray training is long ago (more than 10 years).
    The knowledge must have sunk deep and got confused.
    Sorry,
    Bertus
  10. ErnieM
    Apr 24, 2011
    7,437
    1,626
    Hey we use that very machine where I work!
    We make hybrid microcircuits here (or we did till last December when they moved production off to PA). In this case, "hybrid" means a custom ceramic substrate with printed gold conductors, often printed resistors too, with the chips being literally bare silicon chips connected with .001" gold wires. All that goes inside a package, ceramic or metal, and is hermetically sealed.
    It's used for inspection, inline for things like eutectic flow inspection (how good did the metal flow under the big power die) or sometimes as the initial step in a failure analysis (BEFORE the package is milled open).
    I may even have a buyer for it. ;)
  11. someonesdad
    Jul 7, 2009
    1,585
    141
    That's even better than an estimated value, Ernie. PM with the interested person's email and I'll pass it on to my friend.
  12. magnet18
    Dec 22, 2010
    1,232
    125
    No worries, your point is sound. This is definitely NOT supposed to be used on anything with a brain.
  13. Sparky49
    Jul 16, 2011
    835
    417
    Let's take a picture when I put my hand under it!
    Way hey hey hey!!!!!!!!!:p:eek::rolleyes::D:D
  14. someonesdad
    Jul 7, 2009
    1,585
    141
    Well, that goes without saying. Where I used to work, we only used these machines for our vivisection experiments on managers and HR people.
    Sparky49 likes this.
