fav piece of equipment
Discussion in 'General Electronics Chat' started by Neil Groves, Dec 16, 2011.
  1. Neil Groves
    Sep 14, 2011
    125
    What is your favorite piece of equipment to use?
    in fact i have two, first off is my oscilloscope which since buying it a while back, i don't know how i ever managed without it, it's a basic CRT 2 channel 30Mhz one but i have done some small signal projects that simply could not have been done without it, tracing the signal through the circuit and locating the hotspots was fab.
    My second fav has to be my little pocket sized Analogue multimeter, i loved setting it on the Ω range and watching the needle fly across the face of the meter as it showed me where i hadn't completely broke the copper track on my strip board with the twist drill, or worse still, had forgotten to make a break at all where i needed to, the digi meter just doesn't give me the same satisfaction for some reason.
    My problem is that i get right near the end of construction and rush it so i can get power into the thing and see it work lol
    Neil.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Scope is the favorite to use.
    For "most used"
    1) Fluke 87V
    2) ESR Meter
  3. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Number one on my wish list would be TEK 3054B oscilloscope (can't afford it).
    I do enjoy my Fluke 187.
    Neil What model scope do you have? I am in the market for something with an affordable price.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    For starting out, and even through mid range work with electronics, over 100Mhz scope isn't needed.
    Something like This is under $1k and still provides 4 channels, is lightweight, and is packed with features.
    This is near state of the art, 350Mhz for $1600
    Though I'd suggest something simpler, though still extremely modern featured with fast sampling, only not Tek, Tek is like Fluke, 50% of the price is for the name.
    2 channel 100Mhz for $600
    Or, wait for 10 years, and the $16,000 scope you want will be in the $2,000 range, and that entire time you won't have ANY scope.
  5. R!f@@
    Apr 2, 2009
    8,786
    771
    My Brain....!
    can u beat that ?
  6. Lundwall_Paul
    Oct 18, 2011
    222
    19
    My first choice would be the TDS 3054B but thats $12,200.00. That is 12k too much for my budget. Has anyone rented a scope?
  7. Neil Groves
    Sep 14, 2011
    125
    Hi Paul, i bought the B&K 2020, CRT, 2 channels, 30Mhz at $359 from fry's electronics, a nice little scope for me since i only play with small experimental circuits and audio stuff.
    Neil.
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    Couldn't do too much without a scope, but my desoldering gun has to be next.
  9. Neil Groves
    Sep 14, 2011
    125
    i used to like the desoldering gun at work, great for desoldering ic's and the like from earth planes, i use braid at home though. those desolder pumps are a pain in the butt, you fire the plunger and the work piece flys off the bench lol
    Neil.
  10. BillB3857
    Feb 28, 2009
    2,402
    348
    What plunger? Mine is a pistol grip with an electric vac pump in the housing. Just heat the joint, pull the trigger and WHAMMO... Clear hole! Too bad Marlin P Jones (MPJA) doesn't have them any more.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    In order of how much I use them:
    thumbs
    computer
    fluke 189 multimeter
    wirefox stripper/cutter
    soldering station
    hammer
    drill press
    Tektronix 2430A
    mig welder
    oxy/acetylene torch
    hatchet
    belt grinder
    coal forge
    wish list:
    CNC machine and/or end mill
    lathe
    tig welder
  12. Neil Groves
    Sep 14, 2011
    125
    the desolder pump is that long tube you hold in your hand, push the plunger down with your thumb against spring tension then hit the release button over your molton solder joint, sucking the solder into the tube, sometimes jamming the mechanism....horrible things.
    Neil.
  13. cumesoftware
    Apr 27, 2007
    1,330
    11
    My scope, definitely. It is a great tool for debugging and already helped me many times. :) Next comes my voltmeter and then my soldering irons and desoldering pump.
