https://sites.google.com/site/korgdemo/roland/motherboard
Check out the audio file Voice0006.amr
I have recorded the fault, there may be some background noise because I used my phone but you should still be able to clearly hear what is going on.
Each note played is only one press of a key then you will hear it repeat.
It is not the effects doing this because it happens with all effects turned off.
