I'm not sure what to say on this one. What kinds of faults are you interested in modeling, and in what context. Is this related to what happens in the silicon manufacturing process? Is this related to board or system level diagnosis and repair? Give us something to go on here.Originally posted by Innocent@Apr 23 2006, 12:30 PM
Please i need advice on how to go about this project. Where to source information concerning the project.
Innocent
[post=16449]Quoted post[/post]
[post=16460]Quoted post[/post]
Thanks for showing interest.Originally posted by Innocent@Apr 25 2006, 08:06 AM
[post=16505]Quoted post[/post]
When a board with a verified design stops working we have an easier problem than design verification. Two common board faults, shorts and opens can be modeled by SPST switches. Stimulus response testing can localize and detect these faults.Originally posted by Innocent@Apr 25 2006, 03:10 AM
The area of interest is the diagnosis and repair of boards that make
the digital systems.
[post=16506]Quoted post[/post]
Thanks once againOriginally posted by Papabravo@Apr 25 2006, 01:57 PM
Moving to the components we have with outputs the "stuck at 1" and the "stuck at 0" faults. These are modeled with a pullup or a pulldown resistor. In actual diagnosis a 1K resistor connected to Vcc or Ground will reveal outputs with weak drive which accounts for their inability to drive an output to a stable state.
A broken input, as a result of static damage, can be modeled with an SPST switch. Again stimulus response testing can be used to localize and detect these faults.
Signature analysis is another diagnostic tool that can be used to quickly verify the proper function of a board. Deviation from the signatures can indicate the location of a fault. This technique was popular some years ago, but I havn't heard much about it recently. Try googling the term if you are interested.
Does this help?
[post=16518]Quoted post[/post]
Peatman, J.B.,Digital Hardware Design,McGraw Hill, 1980Originally posted by Innocent@Apr 25 2006, 09:13 PM
Thanks once again
True i will go goggling but i will appreciate if you can give me some reference materials like books or websites.
[post=16546]Quoted post[/post]
by Jake Hertz
by Duane Benson
by Aaron Carman
