Fault Diagnosis / Rectification
Discussion in 'Homework Help' started by Turk, Feb 2, 2009.
  1. Turk
    Jan 27, 2009
    6
    1) One of the switch start flouresent fittings in the general office fails to work. The fitting does not have a fuse within the fitting ..
    1a) State four seperate possible causes of the luminaires failing to function , stating how EACH fault would be identified.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What ideas have you got? How would you go about testing for failures?
