/!\FastPWM++Timer/Counter /!\
Discussion in 'Embedded Systems and Microcontrollers' started by !!Miss.EE!!, Apr 15, 2009.
  1. !!Miss.EE!!
    Thread Starter Active Member
    Oct 17, 2007
    38
    Hello again;
    I have to control a DC motor 9V using "PWM" Using the AVR Butterfly which use Atmel (Atmega 169).
    I need to write a C code to control it using Timer1 and Fast PWM.
    My Question for now is the clock frequency for atmegag169 ??
    I want to set a prescaling but I'm not sure about the clock frequency ??
    also the Top value ???
    what is the different between ICR1 and OCR1B???
    actually I have so many question about PWM and how to code it . I searched through the NET but found what I already Know.
    If you Know a book taking about it can you please help .
    The input is from PORTB using a switch, from 0 - 4 ,each define a duty cycle and frequency .
    My problem is the Clock frequency which I have to know to set the prescaling value and the Top Value. ??
    Help please !
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    A good place to get information is at Smiley Micro's website. It contains a good deal of info on the butterfly and its application.
    There are several AVR experienced members here at AAC who can assist you with your questions. There is also a good forum at www.avrfreaks.net.
    hgmjr
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I did a bit of checking and it appears that the butterfly is intended to operate on its 8Mhz internal RC oscillator. It also has a 32,768 Hz crystal connected so it can be used to provide a convenient clock source for a software based real-time clock application.
    hgmjr
