Sure, got a link?BUT - I strongly suggest you get up to date on photon mass expression as demonstrated in experiments
I don't think the laws are broken, just stretched and taken to the absolute extreme beyond our comprehension. The laws may even have more portions that need added on that we don't know about, such as going from newtons laws to relativity. Just further extremes that need to be analyzed.When we know what happens at the singularity point of a blackhole, where the laws of physics are themselves broken , that is when i believe we'll use space to our advantage and leave the blue marble
Going .9999999C with respect to what exactly?Something that is going 99.99999% has tremendous energy invested in it, almost nuclear in magnitude.
Those relativistic effects again..
Approaching C, the length of the vessel shortens , explaining the meter stick trick. But the mass also increases (the current guess about mass involves interaction with Higgs bosons - if your motion involves interaction with more Higgs bosons, then mass increases) to the extent that any particle that makes it to C also has infinite mass. This is bound to be hard on the crew of any spaceship achieving that speed, not to mention the rest of the universe. It's hard to imagine the rocket motor that can accelerate a mass only slightly less than infinite.
Yes, that is an important distinction. The beam isn't a physical object.uhhh, no. I've heard the same argument with scissors, you have a point you think is moving faster than light, but it is an abstraction. The light doesn't gain speed. Imagine a stream of BBs from a BB gun and sweeping the gun across the heavens. You will have a stream of BBs, but the gaps between the pellets is the only thing that will increase as the stream forms an arc.
Yes, as it is not a physical object it is possible for the "concept" of those objects to appear to travel faster than the speed of light.No, but it is a stream of particles. I think the BB analogy is pretty close.
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
