Fast switching
Discussion in 'The Projects Forum' started by yapjack3, Jun 18, 2008.
  1. yapjack3
    Jun 18, 2008
    I am trying to find the fastest switching solution for my circuit. The switch must be non polarity sensitive which is why at the moment I am using a toggle switch. I think a relay may work faster but am not sure if i should go for a SSR, are they polarity sensitve?
    I have tried SCRs and FETs but these must be attached to the cicuit correctly as they are polarity sensitive.
    Does anyone have any ideas about fast switching?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    How fast is fast to you?
    What is the signal that you are switching? Voltage, amperage?
    You mentioned SSR, did you mean SCR, or perhaps TRIACs?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We might with some details about the circuit. What are you switching?
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    SSRs are not polarity sensitive if one chooses a bi-directional SSR. SSRs for DC are indeed polarity sensitive.
    Switching speed will depend on the specific component, but they will definitely be faster than mechanical relays. An SSR will switch on the order of 1mS or less.
