G'day all - I am building a radio controlled helicopter which is about 1.3 metres in body length. The heli is a model of AirWolf and has machine guns. I would like to build a FAST LED flasher (1 for each gun = 6 total). I have mounted some 3mm LED's into the end of each gun (3 on left hand side and 3 on the right). I have tried a couple of flasher kits from an electronics store, but the flash rate is far too slow. The instructions state how to change the rate of flash but the flash rate is still too slow. One or the circuits uses a 555 timer to flash 2 leds and the other circuit is a metronome using a 4093B and a 4017B IC's and has flash as well as a tick sound from a small speaker. Ths flash and tick sound is ideal except for the flash speed. Any help/links much appreciated,
Thanks,
Regards,
Jim
Thanks,
Regards,
Jim
