fast help plz with my code
Discussion in 'Programmer's Corner' started by ht systems, Aug 18, 2011.
  1. ht systems
    Aug 2, 2011
    71
    hello there , my code is working in the simulation program but when i put it on the board , its not working , would anyone tell me whats the problem ? im using pic16f630 , 4000000 Mhz and its about three flasher leds
    the code is :
    //Defines:
    /**** Macro Substitutions ****
    portc = LED Port Register
    trisc = LED Data Direction Register
    8 = LED Pin Mask
    1 = LED Active Polarity
    //LED0: //Macro function declarations
    void FCD_LED0_LEDOn();
    void FCD_LED0_LEDOff();
    //Defines:
    4 = LED Pin Mask
    //LED1: //Macro function declarations
    void FCD_LED1_LEDOn();
    void FCD_LED1_LEDOff();
    //Defines:
    porta = LED Port Register
    trisa = LED Data Direction Register
    1 = LED Pin Mask
    //LED2: //Macro function declarations
    void FCD_LED2_LEDOn();
    void FCD_LED2_LEDOff();
    //LED0: //Macro implementations
    trisc = trisc & ~8; //Convert pin to output
    if( 1 ) //Active high polarity
    portc = portc | 8;
    else//Active low polarity
    portc = portc & ~8;
    portc = portc & ~8;
    portc = portc | 8;
    //LED1: //Macro implementations
    trisc = trisc & ~4; //Convert pin to output
    portc = portc | 4;
    portc = portc & ~4;
    portc = portc & ~4;
    portc = portc | 4;
    //LED2: //Macro implementations
    trisa = trisa & ~1; //Convert pin to output
    porta = porta | 1;
    porta = porta & ~1;
    porta = porta & ~1;
    porta = porta | 1;
    void main()
    //Initialisation
    cmcon = 0x07;
    //Interrupt initialisation code
    option_reg = 0xC0;
    //Loop
    //Loop: While 1
    while (1)
    //Connection Point
    //Connection Point: [A]: c
    FCC_Main_A:
    //Call Component Macro
    //Call Component Macro: LED(0)::LEDOn
    FCD_LED0_LEDOn();
    //Delay
    //Delay: 1 s
    delay_s(1);
    //Call Component Macro: LED(1)::LEDOff
    FCD_LED1_LEDOff();
    //Delay
    //Delay: 1 s
    delay_s(1);
    //Call Component Macro: LED(2)::LEDOn
    FCD_LED2_LEDOn();
    //Delay
    //Delay: 1 s
    delay_s(1);
    //Call Component Macro: LED(0)::LEDOff
  2. ht systems
    Aug 2, 2011
    71
    huh , always no help ?!!!!!!!!
  3. stahta01
    Member
    Jun 9, 2011
    133
    21
    I suggest you use code tags; a separate set for each code snippet.
    Put the file name before each code tag.
    I see no config statement/fuse list; this is a common place to make mistakes.
    Note: Most of the people like a schematic or at least a description of the circuit.
    The code you posted seems to be missing the end of the main function.
    Code tags start with [ CODE ] and end with [ /CODE ] ; but without the space before and after the square brackets.
    Edit: Thread on how to use code tags
    http://forum.allaboutcircuits.com/showthread.php?t=36849
    Tim S.
  4. stahta01
    Member
    Jun 9, 2011
    133
    21
    I failed to see where you set the value of SFR ANSEL to permit the analog input to work as digital inputs/outputs.
    Edit: But, after reading the datasheet, I am not sure if the 16F630 has analog inputs. I believe it does not have normal analog inputs that require the use of ANSEL to disable.
    Tim S.
  5. ht systems
    Aug 2, 2011
    71
    thank you so much
  6. t06afre
    May 11, 2009
    5,939
    1,222
    It seams you are on the correct track now. But as I said in this sticky http://forum.allaboutcircuits.com/showthread.php?t=44852 Learn to use your tools. Any programmer is whortles without debugging knowhow. The link will get you started in simple debugging then it comes to PICs
