Fast Fourier Analysis
KCHARROIS
Joined Jun 29, 2012
311
Recently been looking into making a audio to FFT but I'd like to understand the math alot more before moving on. So say if I have a sine wave signal like the one attached, and I take the same amount of samples it did, twice the max frequency (nyquist) how do you figure the different main frequencies in the signal. Not particularly interested in the harmonics, if theres a full example you guys might know of or would like to help me out figuring the one below that would be great.
studiot
Joined Nov 9, 2007
4,998
Your pic shows 64 samples over the period which is good for the FFT as you ideally need the number of samples = a power of 2.
Why would you not want the harmonics? This is what the FFT will give you. You don't need it for the fundamental alone.
WBahn
Joined Mar 31, 2012
30,045
Then take the FFT of the waveform if you want a spectral analysis of it.
What's the point here? What is it that you are hoping to walk away from this thread having learned?
KCHARROIS
Joined Jun 29, 2012
311
My goal is to calculate by hand the frequencies that are withing the signal. Sure I could hook it up to a spectrum analyzer and see the different frequencies but I would like to calculate them by hand. Mr Chip, I've added 64 points containing the voltage and time what do I do next?
30,794
Sorry, I don't want to spent the time to edit the numbers from your file.
Please resubmit with just the raw data, no units (V), no other columns.
30,794
Here is the FFT of the data:
5.4000
3.6735 + 2.3598i
5.5301 + 1.8089i
24.9891 +18.4889i
-4.4571 - 4.1551i
-2.9237 - 1.7754i
-0.8351 - 2.0394i
0.5287 - 0.7161i
18.7545 - 0.7450i
-0.1801 - 0.6023i
-1.0048 - 0.5298i
-1.0814 - 0.3137i
-0.5859 - 0.3834i
0.1750 + 0.2315i
0.3741 + 0.3494i
-0.7541 - 0.5660i
-0.8000 - 0.9000i
0.1801 - 1.2694i
0.2651 + 0.4672i
-0.1087 - 0.8807i
1.2193 - 0.5328i
0.1531 + 0.4608i
0.6714 - 0.6653i
0.4180 + 0.0863i
-0.0545 - 0.2450i
0.3879 - 0.1258i
-0.1084 + 0.3079i
-0.0083 + 0.7581i
0.4236 + 0.0955i
0.3731 - 0.6953i
-0.0922 + 0.0096i
-0.2222 - 0.6728i
0.8000
-0.2222 + 0.6728i
-0.0922 - 0.0096i
0.3731 + 0.6953i
0.4236 - 0.0955i
-0.0083 - 0.7581i
-0.1084 - 0.3079i
0.3879 + 0.1258i
-0.0545 + 0.2450i
0.4180 - 0.0863i
0.6714 + 0.6653i
0.1531 - 0.4608i
1.2193 + 0.5328i
-0.1087 + 0.8807i
0.2651 - 0.4672i
0.1801 + 1.2694i
-0.8000 + 0.9000i
-0.7541 + 0.5660i
0.3741 - 0.3494i
0.1750 - 0.2315i
-0.5859 + 0.3834i
-1.0814 + 0.3137i
-1.0048 + 0.5298i
-0.1801 + 0.6023i
18.7545 + 0.7450i
0.5287 + 0.7161i
-0.8351 + 2.0394i
-2.9237 + 1.7754i
-4.4571 + 4.1551i
24.9891 -18.4889i
5.5301 - 1.8089i
3.6735 - 2.3598i
Here is the absolute value:
5.4000
4.3662
5.8184
31.0853
6.0935
3.4206
2.2038
0.8902
18.7693
0.6286
1.1359
1.1260
0.7002
0.2902
0.5118
0.9428
1.2042
1.2821
0.5371
0.8874
1.3306
0.4855
0.9452
0.4268
0.2510
0.4078
0.3264
0.7582
0.4343
0.7890
0.0927
0.7085
0.8000
0.7085
0.0927
0.7890
0.4343
0.7582
0.3264
0.4078
0.2510
0.4268
0.9452
0.4855
1.3306
0.8874
0.5371
1.2821
1.2042
0.9428
0.5118
0.2902
0.7002
1.1260
1.1359
0.6286
18.7693
0.8902
2.2038
3.4206
6.0935
31.0853
5.8184
4.3662
And here is the plot of the absolute value:
Next comes the interpretation of the results.
KCHARROIS
Joined Jun 29, 2012
311
Great I appreciate you showing me this but how did you get the FFT results and then post them in a graph giving you the frequencies?
Thanks again
30,794
The data set consists of 64 points. Hence the FFT will be 64 complex numbers.
Positive frequencies are represented in points 1 to 32.
Negative frequencies are folded around in points 33 to 64. As you can see the results are the same and hence we can ignore the negative frequencies.
Next comes the question of scaling on the x-axis.
There are 32 points, from 0 to 31.
Your record sample is 16 seconds long. Hence your frequency resolution is 1/16 Hz.
The first data point in the FFT result is the amplitude at DC = 0Hz.
The next point is 1/16 Hz.
The 16th point would be 1Hz.
The last point would be 31/16 Hz.
KCHARROIS
Joined Jun 29, 2012
311
So its safe to assume that calculating these values are quite complex and doing this with a pic microcontroller in assembly language using basic opcodes will be even more complex. I saw on the web a bunch of people giving out the code to this over audio so I though it be fun to do it myself maybe I'll just try implementing a bunch of bandpass filter then ADC and then output to LED's.
Thanks again MrChips
30,794
Doing the FFT on a microcontroller is doable. The issues are:
  • size of array
  • memory space
  • speed of microcontroller
For shortest processing time, one would choose integer arithmetic and not floating point arithmetic.
WBahn
Joined Mar 31, 2012
30,045
Implementing the FFT algorithm in a PIC would be pretty straightforward if you do it in C and, at audio frequencies, you have a lot of cycles to throw at it.
The first thing you want to do is understand the DFT algorithm and code that up (on a PC) and then start looking at the FFT implementation, which can be quite a strain to get your mind around the first time. Again, code it up on a PC (in C) and get it working. Then port it to your PIC.
30,794
The objective is to do it in "real time".
Human persistence of vision threshold is about 25Hz. This translates to 50ms.
So your objective is to compute the FFT in within 50ms.
A 64-point FFT in 50ms is very achievable on a microcontroller.
KCHARROIS
Joined Jun 29, 2012
311
Great thanks for the inspiration looked at the DFT I've done math such as integration and derivatives but I'm not quite sure about this formula below. I'll continue reading for better understanding.
WBahn
Joined Mar 31, 2012
30,045
This is summation, which is tightly related to integration. In fact, integration can be thought of as nothing more than summation performed by taking tiny steps with the integral being the result in the limit as the step size goes to zero.
