Fast AND/NAND gate?
Discussion in 'General Electronics Chat' started by MikeML, Nov 16, 2009.
  1. MikeML
    Thread Starter AAC Fanatic!
    Oct 2, 2009
    5,451
    1,066
    I need to gate a 100MHz signal on/off. I would like to use a two-input AND or NAND gate running on a 5V supply. What is a suitable logic family? A Schmitt input gate might be desirable.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Assuming the output can swing between those limits at that speed, what is the maxium propagation delay that can be tolerated? PECL might be the only answer if the requirement is low propagation delay.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Prop delay unimportant. Symmetrical tphl and tplh would be a plus. The duty cycle of the input will be between 40/60%.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What about an SN74AHC132 Schmitt-trigger NAND gate?
    http://focus.ti.com/lit/ds/symlink/sn74ahc132.pdf
    Prop delay 1nS to 11nS, depending on load. Seems symmetrical. You'd have to have a very low output capacitance.
    I really don't know how fast they'll go.
