Faraday Cage style EMC protection
Discussion in 'General Science' started by chrisw1990, Apr 29, 2012.
  1. chrisw1990
    Thread Starter Active Member
    Oct 22, 2011
    543
    41
    maybe title isnt entirely clear but i wonder if a faraday cage style mesh could be used inside a plastic case in order to trap emissions? and protect from external noise?
    say i develop a system, put it in a plastic box, but its in a noisy environment, and is itself noisy.. so wouldnt pass any of the EMC law/tests were it to be tested.. would it be possible to get an aluminium mesh on the inside of the casework and would that then work to shield internal and external emissions?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Don't know, but it seems reasonable.
    While they work, they are not perfect seems like.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  4. chrisw1990
    Oct 22, 2011
    543
    41
    ahhh nice! would work for through plating too.. so the theory is sound then, if someone makes a paint for that purpose.. interesting! reduced cost of plastic with added benefits of metal!
  5. t06afre
    May 11, 2009
    5,939
    1,222
    It will depend very much on the mesh size. A very fine mesh may de the job. But a mesh will always leak. It is much better to use solid materials. This information are for cables but it should give you some idead regarding this matter.
    Most cable use braided shields. Braids typically provide only 60% to 98% coverage and are less effective as shields than solid conductors. Braided shields usually provide just slightly reduced electric field shielding. Except at UHF frequencies. But greatly reduced magnetic field shielding. The reason is that braid distorts the uniformity of the longitudinal shield current. A braid is typically from 5 to 30 dB less effective than a solid shield for protecting against magnetic fields. At higher frequencies, the effectiveness of the braid decreases even more as a result of the holes in the braid.
  6. chrisw1990
    Oct 22, 2011
    543
    41
    ah right, so youd have to have gaps.. small enough to block the wavelengths you want to bloock? like a microwave grill? the holes are small enough to block microwaves?
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  8. chrisw1990
    Oct 22, 2011
    543
    41
    nice find!
    i had found a fine aluminium mesh for auto repair which i argued could be easily folded around the plastic case, perhaps soldered to the ground plane of the device... or not i would imagine not, still.. i shall have to find out! get my 3d printer up and running first :)
  9. Duane P Wetick
    Apr 23, 2009
    408
    19
    We spent a lot of time developing Faraday shields for our metal detectors to minimize capacitive effects on the antennas and also add a degree of shielding to them. In one case, we used a fine copper mesh bonded in place so it couldn't move but the detector could scan thru it. In other instances, a painted surface of graphite collodion, grounded at one end proved very effective. Surface resistivity was about 1 kohm at one cm distance as I recall. The biggest problem that we had to solve was static electricity discharge which of course, would trip the metal detector falsely; ie (no metal). The Faraday shield provided a partial solution for this problem by providing a bleed-off path to ground.
    Cheers, DPW Spent years turning op-amps into heaters.
  10. mcgyvr
    Oct 15, 2009
    4,787
    973
    But the circuit design/routing,etc.. should be evaluated first.. Sometimes ferrite beads,bypass caps,ground planes,trace/track lengths,etc.. are all that's needed to pass EMI/EMC testing.
    A few simple board changes "could" prevent you from reoccurring costs associated with additional shielding,etc...
    Finding an engineer that is well versed in EMI/EMC techniques and have him look it all over. That 1 time cost might be well worth it.
