Faraday Cage Seams Question
nbc2016
Joined Sep 19, 2016
Hello AACers,
I am trying to construct a Faraday Cage to protect my EEG recordings from 60Hz noise, but I am not getting good results. I am using copper mesh screening and a gasketed conductive seal on the door, but I'm not getting much attenuation of signal inside my cage. Commercial manufacturers recommend copper screen for this type of application, so I thought I'd build my own. The amount of 60Hz noise is exactly the same if the door is open or closed! I'm a newbie to these forums, and not an EE, so please be gentle in your comments...
I think the problem must be in the seams between the mesh, but I don't understand what the problem is. I've included an image that shows the way that I've constructed the connection point between the seams, with two possible problems in the construction. Could you please tell me which is more likely to be the problem?
A: The two pieces of screen are connected via pressure (sandwiched between two pieces of wood). It is possible that there is not a good connection at each point, because the wood might not be perfectly square. I could use conductive tape to seal the seams (I don't know how to solder!).
B: The sandwiching between wood is somehow incompatible with a Faraday Cage. I understand that a Faraday Cage works by having a continuous surface, but I couldn't figure out how to keep the mesh up without sandwiching between a wood frame. Will having a protrusion from the continuous surface eliminate the Faraday Cage effect (and if so, could you explain why or point me to resources on constructing a cage?).
Thanks for your help!
nbc2016
AlbertHall
Joined Jun 4, 2014
12,347
A Faraday cage provides shielding against electric fields but not magnetic fields. 60Hz current in wires produces a magnetic field so that may be your problem.
34,470
As Albert stated, a standard Faraday cage does not shield against low frequency magnetic fields, as noted here.
To shield against 60Hz line noise you need a cage wrapped in a magnetically soft material such Permalloy or Mu-metal.
nbc2016
Joined Sep 19, 2016
Based on AlbertHall and crutschow's comments, would shielding nearby wires cables (wrapping in shield) help because it would minimize the magnetic fields generated?
Also, it is typical practice in EEG research to have people inside Faraday Cages, but based on this description of the magnetic fields that would suggest it would be useless?
34,470
Wrapping the cables would likely not help much since the problem is all the mains wires in the walls of the room.
The Faraday cage would help with other types of electromagnetic interference.
Perhaps the Faraday cages they use have magnetic shielding also.
I believe the EMI rooms were I used to work had solid metal magnetic walls plus a layer of copper screens to protect against both EMI and 60Hz magnetic fields.
BR-549
Joined Sep 22, 2013
4,928
I would try two things first. Power your equipment with battery DC.....to confirm the AC supply is not dirty.
And remove florescent lights AND the ballasts.
If necessary.....current loops around the space can deflect B fields.
Papabravo
Joined Feb 24, 2006
21,228
The construction of an anechoic chamber is truly a marvel to behold. I've seen it done twice, and it is not a low budget on the cheap proposition. I think a quarter of a million is about right and that was 25 years ago.
DGElder
Joined Apr 3, 2016
351
As others have said, the Faraday cage will provide little shielding from near field power line emissions which are relatively high current and low voltage sources. The interference is predominately from the 60Hz magnetic field. If you have control over the room's wiring then running the neutral/return wires next to the hot wires would reduce local sources of emissions.
34,470
That must have been a pretty large one. ;)
DickCappels
Joined Aug 21, 2008
10,187
Yes, it is a good idea to solder the seams. Overlapping the screen does not assure low resistance connections. The seams don't need to have a continuous bead of solder for the frequencies of interest but you should assure that all surfaces are electrically connected at all of the joints.
AlbertHall
Joined Jun 4, 2014
12,347
A company I worked for had a 'screened room' where the screening was chicken wire (galvanised steel) which was used for some radio testing at around 100MHz. The ineffectuality of this was clear when we realised that the guy doing the testing was listening to an FM radio in there and getting very good reception :rolleyes:
Papabravo
Joined Feb 24, 2006
21,228
That is right up there with 'Security Theater'
