Fan with temp controler and setable temp range
Discussion in 'Embedded Systems and Microcontrollers' started by FFtravism, Mar 8, 2010.
  1. FFtravism
    Thread Starter Active Member
    Aug 21, 2008
    30
    I am still in research of my project. I am designing a circuit with a PIC that will read the temp of a smoker and if it's low start a fan. If the temp is high stop the fan. The current temp will be displayed on a LCD. Pretty simple really up to this point. If I was always using the same temp it would be fine but I want the option of changing the temp at which the fan goes on/off. I was thinking two buttons (up/down temp) or variable resistor. But I don't know what is the best/easiest way to do this. Any idea's?
    Travis
  2. BMorse
    Sep 26, 2009
    2,675
    234
    What temp sensor are you using?? You could use something like the DS1721 Temp sensor with built in fan controller (there may be some newer versions of this IC, check with manufacturer website), you can set the High, and Low trip points via I2C... then the microcontroller doesn't always have to monitor the fan, but can still poll the sensor for temp.....
    http://www.morse-code.com/HTMLobj-1049/DS1721.pdf
    B. Morse
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Assuming the PIC you are thinking of has an AD converter, I would think the variable resistor would be easiest. No debouncing to worry about. Probably the LCD has enough space to display set temperature and actual temperature.
    It may be good to have a little hysterisis so the fan is not continually switching on and off, ie off 2 degrees above set temperature and on 2 degrees below.
  4. FFtravism
    Aug 21, 2008
    30
    I am using a thermocouple because of the high heat and don't want to melt a little chip. Pic is 16F876.
    This is the link to the design i am working off.
    http://www.ivcity.com/jesse/thermocouple/
    Mark - Yes I am going to have it work with a 2-3 degree swing so it didn't go on/off all the time.
    I don't know how to read or hookup the variable resistor to the AD pin. I am still learning PIC's while building things.
