Fan wires help! which is which yellow, blue , red , & black
Discussion in 'The Projects Forum' started by joulian, Dec 19, 2009.
  1. joulian
    Thread Starter Active Member
    Aug 27, 2009
    53
  2. studiot
    Nov 9, 2007
    5,005
    515
    What did you intend to use it for? You probably don't need the other connections, they will be for speed control via sensors.
  3. joulian
    Aug 27, 2009
    53
    Well i put it on a 110v to 24v transformer .40amps
    but its not turning on fan when i connect the +/-
    I noticed the fan uses 24-60v
    and has a .48amps rating. But I figured that was using its max volts of say 60.
    Hmmm
    I was thinking it might be some speed control also....
    but what with a rheostat?
  4. joulian
    Aug 27, 2009
    53
    Solar furnace. Blow hot air from it into garage.
  5. Paragon
    Member
    Dec 8, 2009
    45
    Is that a 24V AC or DC output transformer? The fan runs off DC.
  6. studiot
    Nov 9, 2007
    5,005
    515
    Doesn't your fan spec sheet say DC?
  7. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
  8. joulian
    Aug 27, 2009
    53
    Yes AC to DC
    I don't understand why its not turning on.
    I connected the +/- to the transformer and even touched the blue and yellow to one another ( if it is a sort of switch it should have worked).
  9. eng1ne
    Member
    Dec 4, 2009
    97
    The input power = 23.52 W @ 48 V (the rated input).
    By P = V.I, I = P/V = 23.52/48 = 0.49 A
    However, at 24 V, I = 23.52/24 = 0.9 A
    And at 60 V, I = 23.52/60 = 0.39 A
    The quoted values are at rated input voltage, as is quoted on the fourth note right on the bottom of the page.
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    Joulian,
    As others have mentioned, I believe you have a 48V fan. I think you will need to apply 48 volts to get the fan operating. Once it is operating, I think you will find that the yellow and blue wires are the collector and the emitter of a sensor transistor. This transistor is there to permit the monitoring of the motor's speed.
    hgmjr
  11. joulian
    Aug 27, 2009
    53
    Ahhhh man, I was afraid this was going to be the reason. I asked the guy at the store if it would work. He said yes, i bought it from surpluscenter.com.
    Ok I just looked for a 48v transformer on that site above.
    Any suggestions? on what to do. I am going over my budget on this entire project. :(
  12. joulian
    Aug 27, 2009
    53
  13. hgmjr
    Jan 28, 2005
    9,030
    214
  14. eng1ne
    Member
    Dec 4, 2009
    97
    hgmjr, the fan that you have suggested requires 1.1 A @ 24 V dc; some 0.6 A over joulian's power supply.
  15. hgmjr
    Jan 28, 2005
    9,030
    214
    Eng1ne,
    Good point. It seems that in order to use the 24 volt fan mentioned in the earlier post, a transformer with a higher power rating will need to be acquired.
    hgmjr
  16. joulian
    Aug 27, 2009
    53
    hmmmm man.
    Any site suggestions like the one i used that would have a good deal on one?
