Fan Temperature controller
Discussion in 'The Projects Forum' started by RodneyB, Oct 1, 2013.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    649
    14
    I have been trying to find a suitable temperature controller for a fan that I need to fit into a housing. Currently the fan is running continuously which is not ideal.
    I have looked on the Internet for a circuit diagram for a very basic temperature controller, and to date Have only found rather complicated circuits.
    Precision here is not critical, I need to just be able to turn the fan on and off within a reasonable tolerance.
    I am basically looking for a circuit diagram or a link to a site where there is a circuit diagram that I can use to build a temperature controller.
    goms likes this.
  2. evilclem
    Member
    Dec 20, 2011
    118
    16
    Are you happy with on/off control or would you like some sort of proportional control?
    A Thermistor for temperature measurement would be idea due to the large resistance change with temperature compared to the more common Thermocouple and RTD.
    A Schmidt Trigger can then be used to turn the fan on and off. Using a Schmidt Trigger permits enough hysteresis to prevent constant on/off cycling.
    The actual selection of resistors for the reference pin on the Schmidt Trigger will depend on what Schmidt Trigger you use and the Thermistor you obtain.
  3. #12
    Nov 30, 2010
    16,703
    7,339
  4. RodneyB
    Apr 28, 2012
    649
    14
    An on off control will be ideal. I am basically trying to move hot air out of a housing, so when it gets to hot, then the fan can come on and blow the hot air out the box. When it cools down, then switch the fan off.
    goms likes this.
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    Just need a bimetal temperature switch.. no other components needed for that..
    Just buy one with the desired on temp and done
  6. wayneh
    Sep 9, 2010
    12,388
    3,244
    A comparator watching a LM35 thermometer is more complicated but would be the most versatile, allowing adjustment of the target temperature and the amount of hysteresis.
    How is the fan powered, is it AC or DC?
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Another thing to consider in enclosure cooling is the environment it is in, if it is dusty or otherwise contaminated, rather than go with negative pressure, is to place a filter on the fan and bring air in, = positive pressure.
    This way the interior stays clean.
    Max.
  8. #12
    Nov 30, 2010
    16,703
    7,339
    Good point. Easier to filter the fan that trying to filter all the places air can get into the box.
