will a 18 volt dc fan work with 12 volt power supply?
8 Thread Starter 805.bluebell Joined Feb 23, 2014 10 Mar 9, 2014 #1 will a 18 volt dc fan work with 12 volt power supply?
bertus Joined Apr 5, 2008 22,270 Mar 9, 2014 #2 Hello, Most DC fans will work on voltages from about 50 to 120 % of the rated voltage. So an 18 Volts DC fan will work from 9 to about 22 Volts. The fan will most likely turn slower on 12 Volts. Bertus
