fan out of 74ALSO4
Discussion in 'General Electronics Chat' started by muni, Sep 2, 2008.
  1. muni
    Thread Starter Active Member
    Jul 29, 2008
    45
    QUESTION FROM GATE PAPER AGAIN. REQUEST ANSWER
    the inverter 74 ALSO4 has the following specifications.
    IOh max = -0.4 mAmp,
    IOL max = 8 mAmp
    IiH max = 20 mAmp
    IiL max = -0.1 mAmp
    Calculate fan out based on the above will be
    a) 10 b) 20 c) 60 d) 100
    i request how to calculate the fan out, though book gives answer but my request is how to calculate this.
    SIR I ALSO REQUEST HOW TO UPLOAD MY FILE THAT IS AVAILABLE IN MY PC. I TRIED THROUGH ATTACHMENT I COULDN'T DO IT. PLEASE TELL ME HOW TO ATTAACH FILE INTO THE FORUM
    THANK YOU
  2. mik3
    Feb 4, 2008
    4,846
    63
    There is an error in yuor values, the input current is greater than the output current, i think it should be in uA rather than mA.
  3. muni
    Jul 29, 2008
    45
    sir in that case plase consider your own values and can u give me formula how to calculate fan out for this ic
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Fanout is defined as the number of inputs an output can drive. Did you Google fanout?
  5. muni
    Jul 29, 2008
    45
    sir i've searched through google i'm getting same threads as searcg results. with wikipedia i'm getting this.
    The fan-out is simply the number of inputs that can be connected to an output before the current required by the inputs exceeds the current that can be delivered by the output while still maintaining correct logic levels. The current figures may be different for the logic zero and logic one states and in that case we must take the pair that give the lower fan-out. This can be expressed mathematically as
    [​IMG] by applying values -0.4 mAmp/ 20 mAmp.
    even then answer doesn't match with any of the choices.
    request for new look
    thank you sir
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Show us your calculations.
    The Wikipedia equation includes the floor function. Do you understand what this is?
  7. muni
    Jul 29, 2008
    45
    no sir i haven't seen the floor functions.
    sir i don't know how to upload a file itno the forum else i can show u the calculation. thank you sir . i'm going through floorfunctions
  8. muni
    Jul 29, 2008
    45
    sir i went through floor functions. but hardly i could understnad any thiing. sorry sir.
    in this particular Q there are no calculations to carry on but i think i need right formula to solve it
  9. Ron H
    Apr 14, 2005
    7,050
    657
    IIH max=20uA, not 20mA, as you stated.
    Below is a schematic which illustrates how fanout is calculated.
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Another factor that makes a firm answer impossible, is that the chip might be driving another logic family (like 74LSxx) and the input requirements will be different, directly affecting fanout.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Don't you think we can assume that the values for IOH, IIH, IOL, and IIL given are intended to bracket the problem? Let's not confuse our OP any more than he/she is already.:D
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Point taken - I'm just too aware of finding that the book didn't cover quite all the situations....
