fan light 2 switch wiring error
Discussion in 'General Electronics Chat' started by Hynes Properties, Aug 20, 2014.
  1. Hynes Properties
    Aug 20, 2014
    I have just wired 1 switch for a light, and one for the connected fan fallowing a diagram. Now both switches turn on light and fan simultaneously. Having trouble finding the error..
  2. Electric Al
    Member
    Nov 6, 2013
    59
    8
    Call an Electrician !
  3. Hynes Properties
    Aug 20, 2014
    Doesn't sound like it..... thanks for the advice anyway.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    Your diagram was wrong or you did it wrong.
    You simply need a "hot" wire into both switches and the output of one switch goes to fan and the output of the other goes to light.
    A switch just disconnects one leg of the circuit (hot and neutral).. usually the "hot" is switched for safety but it's done incorrectly to many times to count..
    see figure 1
    http://i.stack.imgur.com/Ox4Rf.png
  5. adamclark
    Member
    Oct 4, 2013
    472
    6
    Are you using dpst switches? its a pretty basic circuit to wire..
