Hi guys so I have a fan running at 120V 0.5A 60Hz and the other day I tried adding a filter to it. Well at night the filter became entangled in my fan and now it won't start. This happened before but I was able to turn off the fan and untangle it. I guess I just didn't install the filter correctly. So I inspected my fan(Unplugged of course) and the threads are not burnt out, it still spins freely on its bearings and the wires seem to be unburnt as well as connected properly. (There doesn't seem to be a temperature cutoff circuit anywhere on the coils. I guess it was made not to run at a speed that it could overheat at.) So I am assuming it is the capacitor because the regulator still sends power through (I only checked once so I need to double check). Do you guys know if the fan being stuck like this could've caused the starter capacitor to short out? It is a 250v 3uF 50/60Hz capacitor.
