Family Feud Button Project
Discussion in 'The Projects Forum' started by jconstanza, Aug 14, 2008.
  1. jconstanza
    Aug 14, 2008
    Ok I am working on making a button with sound and light. I got the sound working from a recorder module that I bought from radio shack for $11. The light is what I'm having a problem with. Their is a small LED that puts out 1.7v. I bought a couple of LED's from Radio Shack with that voltage, so I soldered 2 wires from the small LED to the ones I bought from RS.
    I need to make the light brighter. The LED seems to sync with the sound. How do I add a 5v+ bulb to the mix. Is it possible? Do I have an alternative? Can someone help please!!!
  2. jconstanza
    Aug 14, 2008
    Anybody???
  3. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  4. jconstanza
    Aug 14, 2008
    Sounds good but I think I need it in lamens terms, I only know so much about electronics. Resistors, I think I know what they are for don't know how to figure out when or how I need them. Same with diodes, transistors, regulators etc. I can read some schematics very little. I know when some components are bad. I know a little but not enough. I greatly appreciate your help.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you create and post a schematic of what you have now?
    This will eliminate a tremendous amount of guesswork on our part.
    I'm afraid that "a recorder module that I bought from radio shack" simply isn't enough information.
    LED's do not "put out 1.7v", but they can have a Vf (forward voltage) of 1.7 if their color is red.
    You will not find bright LEDs at Radio Shack. You will find useful indicator-type LEDs there, but not super-bright LEDs at anything resembling a decent price.
    Post your circuit as it is. Use Windows Paint if you have nothing else - at least we will have some idea of what you are working with. Right now, we have very little information to work with.
