So who is good an batteries?
Looking for some advice on what size of battery I should be using now that we have finally got it working...
12V 12AH did not have the stamina to required to fully test the unit, I got a couple of runs at max with it?
Should I obtain a car battery of around 40AH?
Is this basically correct?
The Amp Hour rating tells you how much amperage is available when discharged evenly over a 20 hour period. The amp hour rating is cumulative, so in order to know how many constant amps the battery will output for 20 hours, you have to divide the amp hour rating by 20. Example: If a battery has an amp hour rating of 75, dividing by 20 = 3.75. Such a battery can carry a 3.75 amp load for 20 hours before dropping to 10.5 volts. (10.5 volts is the fully discharged level, at which point the battery needs to be recharged.) A battery with an amp hour rating of 55 will carry a 2.75 amp load for 20 hours before dropping to 10.5 volts.
So for a 12AH battery I am looking at 0.6A for 20 hours but how can I translate this to a set number of runs? at most I am only running for 1 minute so how can I work out how many runs I can get out of a battery?
Will 12AH be sufficient enough for what I am doing?
