Factor this
Discussion in 'Math' started by Ratch, Jun 28, 2008.
  1. Ratch
    Mar 20, 2007
    1,068
    To the Ineffable All,
    The math forum has not moved for a long time. This problem has stumped a lot of people. How about you? Ratch
    Factor x^4 + 64
  2. mik3
    Feb 4, 2008
    4,846
    63
    do you mean factorize it?
  3. Ratch
    Mar 20, 2007
    1,068
    mik3,
    Yes. You are right. I should have use the verbal form of the word instead of the noun. Ratch
  4. Mark44
    Nov 26, 2007
    626
    Factor is also a verb according to my dictionary (American Heritage Dictionary of the English Language).
    Meanwhile, I am looking to see if I can factor x^{4} + 64.
  5. Mark44
    Nov 26, 2007
    626
    x^{4}x + 64
    = (x - (2 + 2i)) (x - (2 - 2i)) (x - (-2 + 2i)) (x - (-2 - 2i))
    Obviously, the factors have coefficients that are not real numbers, but the problem statement placed no restrictions on the factors.
    The complex numbers in the inner parentheses are the complex fourth roots of -64, which arise from finding the zeroes of the equation x^{4} + 64 = 0, or x^{4} = -64. These roots all have magnitude 2\sqrt{2} and have angles of, respectively, 45 degrees, 135 degrees, 225 degrees, and 315 degrees.
  6. Ratch
    Mar 20, 2007
    1,068
    Mark44,
    Yes, your answer is correct, and I should have specified that complex conjugate terms were not necessary. It factors easily into two quadratic expressions. Can you tell me how one could solve it? Ratch
  7. Mark44
    Nov 26, 2007
    626
    How's this? (x^{2} + 8i) (x^{2} - 8i)
    The two quadratic factors can be further factored into the linear factors in my earlier post.
    Mark
  8. studiot
    Nov 9, 2007
    5,005
    515
    I think Ratch was looking for
    (x^2-4x+8)(x^2+4x+8)
    Which do not factorise further in the real world.
  9. Mark44
    Nov 26, 2007
    626
    Studiot, one should be able to multiply selected pairs of the linear factors I gave to come up with the two quadratics you showed. "One" here means I haven't done this.
  10. studiot
    Nov 9, 2007
    5,005
    515
  11. Ratch
    Mar 20, 2007
    1,068
    Studiot did what I was looking for. I was not looking to find the roots, only to factorize the expression. I don't know what the method of undetermined coefficients is, but my method is called completing the square. This problem came from a high school textbook about 50 years ago.
    x^4+64 = x^4+16x^2+64 -16x^2= (x^2+8)^2-(4x)^2
    Which is the difference of two squares, and easily expands to studiot's answer. Ratch
  12. Mark44
    Nov 26, 2007
    626
    If so, you should have stated that you wanted factors with real coefficients.
    Finding the roots of a polynomial and factoring it are nearly identical problems. For a polynomial an*x^{n} + a(n-1)*x^{n-1} + a(n-2)*x^{n-2} + ... + a1*x + a0, if the roots are r1, r2, r3, ..., rn, then the factored form is (x - r1)*(x - r2)*(x - r3)*...*(x - rn).
    If you know the roots of a polynomial, you know its factorization.
    Some of you might be wondering why the polynomial Ratch gave has so many factorizations. I provided two of them, and Studiot provided another. The linear factorization I provided earlier in this thread is irreducible. Each of the other two factorizations (the ones with quadratic expressions) can be factored further into linear factors, as long as you allow coefficients from the complex numbers.
    If we're working with integers instead of polynomials, there is a similar situation. 100 can be factored in several ways:
    4 * 25
    5 * 20
    2 * 50
    and a few more.
    There is one factorization that is better than all others:
    2 * 2 * 5 * 5
    Except for the order in which the factors appear, this factorization into primes is unique. If factors that aren't primes are allowed, then a given factorization is not guaranteed to be unique.
    Mark
  13. Ratch
    Mar 20, 2007
    1,068
    Mark44,
    Yes, I should have specified factorizing into two quadratics. Ratch
