FA-10046 Time Code Display problem
Discussion in 'General Electronics Chat' started by bushrat, Apr 15, 2016.
  1. bushrat
    Nov 29, 2014
    97
    23
    Hello everybody,
    I came across a interesting piece of equipment, and I decided to take it home and try to get it to work. I found it in recycle bin, so i know it was not needed anymore.
    Well, the display does not show anything. I assumed that the fuse was bad or some caps popped inside,
    The inside did not show any burn marks or caps damaged,
    The display still works (it appears,) which means that power does go through the circuit.. I'm assuming that the EPROM is erased since it is exposed.Does anyone know where I can get the code to upload it? I would like to try to get this equipment to work. If not, I will probably take it apart for components; unless someone wants this very bad for some reason..
