f to v converter
Discussion in 'General Electronics Chat' started by mechtronics, Aug 5, 2011.
  1. mechtronics
    Jul 30, 2011
    10
    does any 1 kno can a 10 volt output be achieved on the tc9400 frequency to voltage converter, from any input frequency applied to it?? a diagram would be much appreciated if any body has one?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. mechtronics
    Jul 30, 2011
    10
    it states in the data sheet that:
    The devices can also be used as highly accurate
    Frequency-to-Voltage (F/V) converters, accepting
    virtually any input frequency waveform and providing a​
    linearly proportional voltage output.
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    Section 6.1 on page 14 has the formula for Vo. I'd start there.
  5. mechtronics
    Jul 30, 2011
    10
    this can be any output voltage you want to a given frequency so i suppose ya 10 volts is what i need.
  6. Jaguarjoe
    Apr 7, 2010
    770
    90
    Don't fall for sucker traps like expecting an output voltage to be higher than the supply voltage.
  7. mechtronics
    Jul 30, 2011
    10
    i dont want the o/p voltage to be higher than supply voltage.
