f to v converter using LM331
Discussion in 'The Projects Forum' started by jayeshvc777, Sep 30, 2013.
  1. jayeshvc777
    Sep 29, 2013
    6
    actually i dont know anything about LM331 and how it works as freq to vltg convertor ,so guyz plz help me for this project as soon as possible.
    I followed 1 ckt frm google,which is displayed in this post plz look after that and plz give ur views because i implemented this ckt but there was no o/p [​IMG]
    i used function generator at input side and multimeter at output, but there was no output for any variation in frequency (100hz-100khz)
    as i said i dont know much about it so plz help me out for this project and if there is another ic or some ckt plz post it
    thank you for reading......and plz reply:):):)
  2. ronv
    Nov 12, 2008
    3,392
    1,448
    Is your input voltage 0 to 15 volts? OR ?
    jayeshvc777 likes this.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Did you read the datasheet, as opposed to some random image?
  4. jayeshvc777
    Sep 29, 2013
    6
    first of all thanks for reading & replying this thread.......actually i badly need help to complete this project.
    ronv- from the image i provided, i have given frequency ranging from 1khz to 100khz from function generator at pin 6, a +15v dc as mentioned in the image and multimeter at pin 1 to check voltage o/p,but problem is such that there is no output at any given frquency
    see as i told i dont have much info about this ic LM331 and the circuit
    so plz see the circuit and tell me what is going wrong.....plz
    i may be completely wrong so please check the circuit and post me as soon as possible......thanks..
  5. jayeshvc777
    Sep 29, 2013
    6
    tshuck thanks for replying actually i took a random image from a site called circuitstoday ......and plz help me for this this circuit.....
  6. wayneh
    Sep 9, 2010
    12,368
    3,224
    FWIW, that circuit comes from Figure 17 of the TI data sheet.
    Perhaps you should supply a photo of your build. There's likely an error. Either that or the IC is dead.
  7. jayeshvc777
    Sep 29, 2013
    6
    wayneh- thanks for replying, i looked over circuit which u provided. i need to know more about following things plz
    1) about i/p- Is it ok if i give frequency from frequency generator?
    2) where i need to see o/p - multimeter or CRO
    3)is vs is kept strickly +15volt?
    4)in Rs i should connect 5 ohm resistor or a potentiometer ?
    soon i will tag photo of my build circuit
  8. wayneh
    Sep 9, 2010
    12,368
    3,224
    Yes, but the generator must share a common ground with your circuit.
    A multimeter should be fine.
    I think the voltage needs to be regulated but I don't think it has to be 15V. But you might need to change some of the biasing resistors if you use a different supply voltage.
    A fixed resistor, say 2.7K, would work, but the 5K pot
    allows for adjusting the output.
  9. jayeshvc777
    Sep 29, 2013
    6
    thanks for the info,i will b trying this tomorrow so i will let u knw......thanks again.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Note that there is a rather significant difference in the output cap size between the two schematics. 1uF (in the datasheet schematic) is equivalent to 1,000,000pF, or 10,000 times greater than the 100pF in the first schematic. That shouldn't affect whether the IC is working or not, but it certainly will make the output more stable, particularly in the lower frequency ranges.
  11. jayeshvc777
    Sep 29, 2013
    6
    so which cap would b perfect 1microf or 100pf.....??????
