I have a Technics SL-D303 turntable that has a problem. Hoping that you might be able to give me a bit of advice. The turntable has very low torque, will hold constant speed if you help the turntable get moving, but it just does not have the power to pull up the speed. I have checked everything in the drive circuit and found nothing defective. The control IC gets really hot. Any thoughts?
Thank you,
David
Thank you,
David
