I am to create a net using only NAND gates to achieve the function u=D+CB'A'=/De Morgan/=
(D'(CB'A')')'
All my attempts to create the function u has resulted in nets using far more NAND gates that seem logical (Using the NAND gate combinations in order to replicate other types of gates). The task is to use only the minimum amount of NAND gates and all NAND gates have 2 inputs.
Any solutions or tips? if you post a solution please explain the though process so I learn until next time
(D'(CB'A')')'
